problem with my new edelbrock manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2009, 09:16 AM
i just got a really good deal on a edelbrock performer rpm intake. the guy said it was brand new. and it looks brand new except for surface that goes on the heads. its extremely rough on one side (maybe .010 deep machining marks), and somewhat smoother on the other side (maybe .050 in the worst spot). the carb deck is just fine. it has a nice clean polish on it.
so is this a good manifold or not?
thanks
Old 03-12-2009, 09:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you meant 0.10 on the rough side and 0.050" on the better side, I would've passed on it.
Without a massive amount of sealer and thick gaskets, I don't see it sealing very well. It will cost you more to machine it smooth than another, better used one will cost, IMHO. Plus all that machining could play hell on the port/gasket alignment.
Old 03-12-2009, 11:57 AM
do you think it came from the factory like this? or has someone messed around with it?
Old 03-12-2009, 12:34 PM
techinspector1's Avatar
Wiki Edits: 326
Hard to tell if it has been tweaked on. Here's an article I wrote for the wiki that may help you.....
http://www.crankshaftcoalition.com/w...ak%2C_internal
Intake Manifold won't fit Andrew7dg Engine 18 12-15-2008 08:27 AM
Strange idle problem – part warm engine 78transam Engine 2 10-26-2007 05:16 PM
Edelbrock Carb problem? busterwivell Engine 8 07-29-2007 07:49 AM
Edelbrock Carb Choke wire problem rakundig Engine 2 01-25-2004 08:34 PM
Edelbrock 1405 problem BrackneyC Engine 26 09-23-2003 10:48 AM
