problem...thinking it might be electrical. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 04:20 PM
one of my friends has a 91 nissan d21 pickup, 2.4L 4 cylinder, to be honest im not sure whats wrong with it, if the battery is fully charged it runs fine but none of the gauges work, and if u run it hard every now and then it starts to sputter, like it's starving for gas, i was thinking the alternator was bad, not charging the battery and when the battery dies, the fuel pump wont work. well someone else told me that it might be the computer,(they used to have the same problem with the same vehicle). anyone that could help with this there advice would be much appreciated. thanks for your time.
Old 09-11-2007, 07:33 PM
Just the facts
There's no doubt in my mind it's electrical.
Have him charge the battery, and drive it to a local AutoZone. Have them test the alternator, and plug in to the diagnostic port to see the codes.
This will either find the problem or eliminate the most likely causes and easiest (although not the cheapest) fixes.
If that don't do it, clean battery connections, double check/clean ground wires. Verify all fuses are good. Finally check for damage to wires.
Steve
Ford Electrical Problem BigJoeGrit Electrical 6 01-18-2007 06:41 AM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 05:46 PM
Electrical Problem with Motorcycle???? 71gtx Electrical 6 04-13-2005 04:53 AM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
66 Mustang Electrical Problem ponybuster Electrical 4 09-24-2003 09:33 PM
