Problem w/ Powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 02:07 PM
BadBehavior's Avatar
Recently built a PG "shorty" Using a TCI eliminator. It seems I can engage the shaft spline but as you can see the red clay, it's not engaging pump tangs.
Is it possible that the spline is not seated deep enough? IF so whats my solution, when I tap the spline it does seem to be bottomed out against something solid??
I hope I do not have to open this thing again, but whatever, really need some input.
Larry
ID:	74494   Click image for larger version
ID:	74495   Click image for larger version
Old 06-02-2013, 03:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is your eliminator drive for a glide spline or turbo spline?
The glide input shaft looks too long. Was this a complete trans when you began?
What gear ratio planet is used?
Is the washer seated in the planet?
Old 06-03-2013, 07:43 AM
First off, I was hoping you would respond, Thanks, this is a new territory for and old garage hack.
1.'Glide
2. Yes, pulled from running '67 C10
3. 1:82
4: I have Carl Munroes(RIP) book. He states this washer stays in as opposed to the 1:76 that falls out. If I pull this thing apart I guess this the only way I'll know. I wish the book would have listed the measurement of protrusion of the spline from the pump outer spline, which would always be the same.
UPDATE: I went back and I got the eliminator to go to the depth seen in the pic and the red clay on the tip of the shaft has not been crushed. Should this be able to go deeper? Do I just need to keep working it?
This is going in a 350-400 HP V-drive for skiing mostly, so this will not be "hammmered" on real hard. Just want it safe.
PS: I tried explaining This to TCI, NO JOY, so Thanks for hangin' in there with me.
Larry R
ID:	74581   Click image for larger version
Old 06-03-2013, 01:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
looks like the drive may be going deep enough.
You can stand the glide on it's end, look into the trans with input shaft removed if needed.
Most of these drives are built with turbo splines. Make sure you have the glide OE spline in the drive
Old 06-03-2013, 05:09 PM
"looks like the drive may be going deep enough". Is this all that needs to be engaged?, seems minimal, would this satisfy you if it was your unit?
"You can stand the glide on it's end, look into the trans with input shaft removed if needed." Little slow on the uptake here on this one, what am I looking for?
"turbo splines" are you referring to the hardened aftermarket splines or the older PG's
Again thanks for your time, I went lurking and like the morris minor project, what are you going to run for Engine??
Larry
powerglide problem nitro_baller4692 Transmission - Rearend 1 09-13-2010 12:05 PM
powerglide reverse problem dirtrackin Transmission - Rearend 2 03-21-2010 12:32 PM
powerglide problem 63chevy Transmission - Rearend 5 10-24-2009 05:20 PM
Powerglide problem 58lincoln Transmission - Rearend 2 11-30-2008 08:46 PM
Powerglide problem WarWagon Transmission - Rearend 7 10-19-2006 02:17 PM
