Problem w/ TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2002, 01:07 PM
New Member
Question Problem w/ TH350
I just put a tci streetfighter converter in my car. 3000-3500 stall. The problem iam having is at higher rpms it feels like something is slipping. Like if i downshift to 2nd and floor it, at higher rpms it feels like something is sliping and the cars not as fast as it was before. The converter was new going in and it never did this before the swap. Does anybody have any ideas?
Old 09-24-2002, 05:23 PM
Post
Whats the engine's specs?
Old 09-24-2002, 05:51 PM
New Member
Post
its a 350, about a .530 lift cam. Probably putting out around 420-430 to the flywheel.
What its doing kind of reminds me of when the clutch slips with a standard trans.
Old 09-29-2002, 04:39 PM
Post
I would swap the converter out for a different one even a stock one to see if the problem is still there. If the problem goes away it's the converter, sounds like the stator is locked up.
