Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems with 302 in 1987 Ranger
  #31 (permalink)
Old 06-26-2012, 04:24 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Originally Posted by Irelands child
Accelerator pump link on a 1405/1406 goes in the center hole.
Super simple carb for the average guy ---
7/16 float level, 15/16 float drop. Follow the IB for the proper jets, rods and springs. You do have to read it a couple times for it to make sense. This is the first of 2 1405's (one with the choke option) I rebuilt last week - the other and still cruddy(!!) is behind it:
Timing should be no more then 10* BTDC
Ford OEM distributors only run on ported vacuum - pass side port on a 1405/6. Cap the other small one off or if you have a C4, run that line to the transmission
The front big vacuum port is for the PCV, rear for power brakes.
This photo shows #1, and the distributor rotates CCW as you look down on it (this is an HO wired dist, but #1 stays in the same place either way)
Get a vacuum gauge on that engine. If it has a stock camshaft, it will run 17-21 inches (mine is 17-18 with a medium warm camshaft)
Unless you understand pedestal mount rocker arms, don't disassemble until you do - they can and WILL cause you to suffer acid reflux
Hi Dave and Ace hogger. I am thinking the cam timing is out if you have dialled your distributor in at around 8 and still have to go to 18 for it to run.
That would be about a tooth out on the camtiming. By the way upstater , what is a "medium warm cam" Down here our steaks off the BBQ are medium warm.
The Following User Says Thank You to 67Mustang Al. For This Useful Post:
acehogg69 (06-29-2012)
