Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems with 302 in 1987 Ranger
  #41 (permalink)
Old 06-29-2012, 08:36 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by acehogg69 View Post
Well she is running. Got the timing set at just over 10BTC and got the idle screw set. Sounds great! All I got left is to finish up the fuel lines and adjust the AOD. Anyone ever done this is it tricky at all? I got the gauge Lokar suggests.
Set it exactly how Lokar AND Ford recommend. If TV is wrong, the transmission can be toast real quick. As far as tricky, no.
http://www.lokar.com/downloads/pdf-i...aod_kd_kit.pdf
and another:
Ford AOD Transmission
and last:
Using the Ford AOD with a Holley carburetor
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
acehogg69 (06-29-2012)
