Problems with 302 in 1987 Ranger
I have a 87 Ranger with a 302. Not sure what year the block is out of. It is not the H.O. engine. I have an edlebrock 1405 600CFM mounted to a power plus typoon intake. The firing order is 1,5,4 etc distributer is set TDC. If it was off wouldn't the rotor button not be hitting the #1 cyclinder? I am at loss. btw all the parts mentioned are new outta the box. I put new lifters, intake manifold, carb, radiator and went to an electric fan. I am runnning at 5psi fuel. I put a regulator and gauge. Any ideas or things I am over looking???
Would you be specific on what the problem is? The engine does not run at all? Runs poorly? Back fires?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Sorry, been beating my head against the wall the last 3 days. It will start up but runs ruff, won't idle, if I put it in gear she falls straight on her butt. Getting some backfire through the carb. Timing is running about 20 BTDC. I retorqued the carb, intake and double checked all my wires.
Try dropping your initial timing back to 10 - 12*, vacuum advance disconnected and plugged at the carb. No vacuum leaks?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Floats could be the problem, but they'd have to be completely closing off the fuel supply to cause this problem. Does it act like it's running out of fuel or going rich? How far out do you have the idle mix screws? I run a 1405 and a 1406 on my T, they're easy carbs to work with. I've attached the float adjustment specs.
What's your fuel pressure? They like about 5.5 psi.
The screws are backed out 2.5 turns as I read to do. The press is running a solid 5psi. It kinda sounds like the timing is off. I think it sounds like it's loading up with fuel. I am not sure how to tell really. But if I had to guess it acts like it's not getting enough fuel. And I am worried about the timing running so high. Before I tore it down she was running around 14-16. Also I read the linkage for the pump on the front drivers side of the carb to move the linkage down to the lowest hole. Anyone heard of this??
I also just read that the vacuum for vac advance should be hooked up on the passengers side port. I had it on the drivers side. Could that be part of my issues?
If it seems like it's loading up you want to shorten the pump stroke,put it in the top hole.The 1405 & 1406 are a later version of the Carter AFB here is some great tuning info you should save:http://www.mymopar.com/downloads/carterafbtuning.pdf I am also running a 302 similar setup (see Pic)
Well I put the accell pump to the top hole, put the vacuum line on the passenger side port and it is running worse. I got the idle screws out 2.5 turns. When I did have her running I had to put the timing around 18 to keep it running. I am getting a back fire through the carb before it dies out.
A back fire normally means there is an issue with timing. The spark plug is firing with the intake valve open hence the fire coming back up through the carb. Hope you have an extinguisher handy.
Al |
I am at a loss. I guess I might pull the valve cover...ughhh gotta pull the heater box to do that. Now when I do that, what at I looking for on the rocker arm to verify I am on the compression stroke. I am also wondering about a vacuum leak but until I get it running no way to really check or set the ignition timing. Also once I verify compression stroke and the rotor button is straight up on the #1 post and the stator is centered on the little gear which way would I want to turn the distributer to get it about 8-10 deg OTC?
68Nova, On your Eddies which hole are you running the accelerator pump linkage? I have the and also read use the bottom. Of course the book makes no mention of it.
Now you need to turn this pulley slightly with a socket on the centre bolt until you estimate 8-10 degrees BTDC(before top dead centre) In other words you want the piston to be just shy of the top of its stroke when the spark plug fires. To make sure you are turning the pullley the right direction, watch the rotor. It should turn anti clockwise when the crank pulley is going in the right direction. This is where you want the piston to be when you crack a spark from the distributor. All you need to do now is sit number one plug in its lead on top of the block, turn the ignition on, then rotate the distributor very slowly by hand in a CLOCKWISE direction until it passes the number one post inside the cap and fires off a spark. You will have to go backwards and forwards a couple of times so you know where it is. Only lock the dist bolt after a "CLOCKWISE' spark happens at the plug. You set the 8 degrees on the crankshaft pulley, not the distributor. this is just to get you started. A timing light is used later on once the engine is running. |
| 1987 ford 302 sefi to carb and beyond | BACKYARDBUILT | Hotrodding Basics | 3 | 09-07-2011 12:12 AM |
| 302 in a ranger? | 91 ranger | Hotrodding Basics | 4 | 02-12-2010 04:18 PM |
| need help with problem on 1987 ford ranger. | ranger1213 | Engine | 2 | 09-16-2009 07:07 AM |
| 350chev in a 1987 ford ranger | chevy-ranger | Introduce Yourself | 1 | 05-19-2009 05:28 AM |
| ignition timing 1987 ford ranger 2.9 v6 EFI 4X4 | amblessed4life | Introduce Yourself | 1 | 05-21-2006 01:38 PM |
