problems 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2007, 03:35 PM
problems 383
just put together a 383 stroker just put the mororso oil pan on and primed the lifters and ran the roller rockers turned it over by hand seeing how its still on the stand and heard a ping somewere in the bottom been trying to figure out what it may be really didnt want to drain it and tear it back down but with $4000 already invested havnt got the intake or carb yet so to be on the safe side im going to but the pan is for stroker up to 4.125 only 3.75 crank any sugestions what it might be
Old 12-13-2007, 04:10 PM
With 4 thousand dollars on the line, I go back in it, can't think of any good reason why it should make a sound while being rotated. Experience says it's a counterweight clipping an oil scraper if you used one. Even that sends me back in.
Bogie
Old 12-13-2007, 04:27 PM
mike's hotrods's Avatar
[QUOTE= Experience says it's a counterweight clipping an oil scraper
Bogie[/QUOTE]
thats what I'd guess, or maybe a loose fastner or hardware of some sort. oil pump spring?
Old 12-13-2007, 05:31 PM
no scraper and yes probably tomorrow tear it back down just dont know what it would be
Old 12-14-2007, 01:29 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Do you have assembly lube on the rod bearings or were they put together dry?
Old 12-14-2007, 04:39 AM
really feeling stupid now was the oil pan gasket i didnt notch it were the block was clearenced was flipping in there when the rods came around i used felpros one peice the thick blue one hoping thats what it was no marks on the pan going to put it back together today to see it wasting stopping when i was turning it over was just hearing a pinging sound in the bottom i have rebuilt about 30 350s butnever have done a stroker just every little thing freaks me out for what i got in this could have done a few 350s restoring a 78 chevy 4x4 shortbed frame off got the frame sandblasted and painted a nd the differentails done just trying to get the motor done so i can get back on the truck its self
Old 12-14-2007, 07:28 AM
79C10's Avatar
Viva la Migra!!
don't feel stupid.... you figured out the problem.
Now if you DIDN'T try to find the source of the sound.....THAT would be stupid!
BTW - sounds like a nice build!
383 Rod & Cam clearance crusherdbuzz Engine 9 11-12-2006 07:17 PM
383 or 400?? KFXrider88 Engine 7 06-13-2006 06:45 AM
383 vs. 396 Malibu73 Engine 15 11-30-2005 01:30 PM
383 0r 406??? Zubair Engine 60 10-14-2005 08:53 PM
.60 over 383 SBC Questions Mustangsaly Engine 8 06-28-2005 01:18 PM
