Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "problems with a crate motor 350/330hp??"
Old 09-18-2003, 11:38 PM
Vern Bradford's Avatar
Vern Bradford Vern Bradford is offline
I agree with Bob that the problem is in the piston area. You might run a compression test on the engine or a leak down test to see what the problem is. It could even be a broken ring. At any rate it is best to pull it a part now and possibly save some money in the long run. Good Luck,
Vern
