problems with dodge 360 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 02:38 PM
topwrench's Avatar
Last journal entry: fish carb
Friend of mine has a 1997 dodge 3/4 ton van with a 360 and auto trans.
Here is my question.
Eng was really running badly at idle,so before i did anything else I changed plugs.
Comp test at this point was 150 psi across the board.
Changed all ign wires,dist cap,rotor,module in distributor,ign coil.
Now o.b.d. is saying
Codes:
300=multi cyl misfire
and 304 through 308 = cyl 4,5,6,8 misfire
I just road tested this van and seems to have plenty of power and running on all cyls, but at idle its a dog, quits everytime you go in rev.and then apply brakes.
This van sat for a long time in someones back yard.
Could this problem be in the fuel inj.system?
If it is Im about ready to go to junk yard n buy 2bbl manifold,carb,distributor
and remove pump from tank and put in electric pusher pump.
Injectors are like 70 bucks each and it could be most are bad.
Someone took the cat.conv. off this a long time ago!
Old 08-18-2010, 02:42 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Codes:
Have you checked it over for vacuum leaks ? A bad PCV valve , hoses , etc .
Old 08-18-2010, 02:55 PM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
is this eng equipped with an egr valve? if so it could be stuck open
Old 08-18-2010, 03:01 PM
T-bucket23's Avatar
Wiki Edits: 26
What kind of plugs did you install. If they are Bosch, take them out and get champions or whatever it had from the factory. We have had a lot of issues with Bosch plugs in Chrysler products. What did you gap the plugs at.
I would also take a look to make sure you didn't break a vacuum line somewhere
Chet
Old 08-18-2010, 03:02 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Missed that . That could very well be also .
Old 08-18-2010, 03:18 PM
topwrench's Avatar
Ok well I,ve got some stuff to check then.
I did not check e.g.r.
I will take plugs out and change to champions I did use Bosch
I did squeeze va. lines one by one with pliers and didnt seem to make a diff.
I will check vacumm with gauge and see what it is.
I sure appreciate the help,Im no dodge guy.
So i will post what its like after all your suggestions,this person doesnt have a lot of money and Im doing this Pro-bono.
So thanks again Chet and 27t
Al....
Old 08-18-2010, 03:27 PM
T-bucket23's Avatar
Wiki Edits: 26
We had a Dodge truck that would barely run a few months ago, had brand new Bosch plugs, after checking everything we replaced them with I believe Champions and it ran perfect. We have seen this a few other times as well
Chet
Old 08-18-2010, 03:31 PM
topwrench's Avatar
Im on my way to parts store right now to get a set champions.
I ll look up the gap and gap them.
Check vacumm with gauge and I can check E.G.R. with hand vacumm pump.
Old 08-18-2010, 04:13 PM
27 t's Avatar
best way to ck the egr valve on that would be to loosen the egr bolt lift it up slide some cardboard or equivalent under the egr. tighten it down and start the truck and see how she runs this will eliminate it completely..
Old 08-18-2010, 04:14 PM
topwrench's Avatar
No, i didnt , didnt have time,worked on it while she did weekly landscaping,so just basically threw some parts at it.
Im gonna check all of what you guys said,cant do it til Sunday, she's a my landscaper and works from just about dawn til dusk 6 days a week.
I dont really have a good knowledge base on the Chrysler product.
So all your help is certainly appreciated!!
Thanks
Al
Old 08-22-2010, 04:24 PM
topwrench's Avatar
Hey thanks for all your help everybody!!
I went today n changed plugs to champions...What a difference.
I also found 2 bad injectors #6n#8, I arrived at injector conclusuion by looks of plugs, n swapped them with 2 others to verify.
So basically I just threw a set of plugs in it n replaced 2 injectors..
Runs like a top now..
This engine doesnt have e.g.r. n I was really surprised at the low f.pressure Chrisler runs.. about 28 psi.
thanks!!!! Al
Old 08-22-2010, 04:57 PM
T-bucket23's Avatar
Wiki Edits: 26
glad it worked out. I don't know what it is with the Bosch plugs but Chrysler products don't like them at all.
Chet
Old 08-22-2010, 07:39 PM
"I don't know what it is with the Bosch plugs but Chrysler products don't like them at all."
must be the Daimler connection
Old 08-22-2010, 09:00 PM
topwrench's Avatar
Hey , I dont know what it is with the plugs, but all you guys sure enlightned me,and I sure DO APRECIATE your advise.
That van is 3/4 ton n has 360 magnum.
Sure has the power now!!!
Thanks again
Al
Old 08-23-2010, 10:17 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
thanks!!!! Al
I put a pair of Bosch plugs in a snowmobile years ago and would have had to walk home if I hadn't had a pair of rusted up old Champions under the seat . Threw those Boschs as far as I could .
supercharger or blower for dodge 360? Johnny4311 Engine 13 07-12-2007 10:15 AM
need help with dodge 360 legionlleh Engine 2 02-06-2007 10:53 PM
77 Dodge Van Firing Problems EazyDuzIt102 Engine 12 05-22-2006 07:01 PM
How do I identify a 318, 340, 360 Mopar?? STATUTORY GRAPE Engine 4 04-19-2006 09:15 PM
dodge ram torque converter problems ram 1500 Transmission - Rearend 1 02-02-2006 07:04 PM
