problems on fresh build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2005, 11:54 PM
Hi All,
Just completed the install of my new motor.
350 SBC .30 over
Forged pistons
6.0 rods
Lunati roller cam and lifters 290 advertised duration 522 lift
Roller rockers 1.6
Dart 215 pro1 heads
Demon 750
Airgap intake
Transmission 700R4
MSD ready to run dist and 6AL ignition box
I dont know what the rear gears are.
I didnt build the motor had a local machine shop build it.
After the install it started fine.
Oil pressure is good temp is also good.
On the distributor I changed the advance stop bushing to the red one and also changed to
the blue light spring and silver light spring according to the MSD chart
this brings the mechanical advance to 28 degree's at 3200 rpm (is that right?)..so when I try to set the initial at 8 for a total of 36 degree's headers start to glow red hot at that point I retard the timing back to 0 initial degrees. it runs ok but seems to lack power and the idle fluctuates about 100 rpm up and down. Kind of a surging thing …What am I doing wrong….sorry about babbling on any and advice is greatly appreciated
Old 06-16-2005, 11:57 PM
I forgot to mention that I diconected the vacum advance canister.
Does that matter?
Old 06-17-2005, 05:08 AM
poncho62's Avatar
Wiki Edits: 5
You need more timing...try 4 degrees at idle, to start.
Also, I think you have a carb problem (surging)................check for vacuum leaks 1st.
Old 06-17-2005, 05:52 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Your timing is all wrong. You are going to want at least 18 degrees initial advance and likely a bit more. You need to increase initial advance a bunch and limit total advance to 34-36 degrees. That will take care of the laziness and glowing headers. Start with that and let us know how it runs. Should be a bunch better. If you have a carb problem, then you can tune it.
Chris
Old 06-17-2005, 06:05 AM
Last journal entry: PICTURE TEST
set-up
Something seams wrong here. I think the red bushing is the biggest in the kit isn't it??? I don't have my chart in front of me. If it is then you should only be getting like 8 maybe 10 deg of advance... Did you confirm with a timing light that the distributor really has 28 degrees of advance in it?????? Did you also confirm that the timing marks are correct????
Like Chris stated you will need a timing curve more like 16 or 18 initial (with out the vacuum advance hooked up) And 36 or 38 total mechanical.... And i would not allow more then about 10 degrees in the vacuum can........
Keith
Old 06-17-2005, 06:38 AM
coldknock's Avatar
Sounds to me like you setting it at 8* After TDC and that's what is making the headers glow. It should be set Before TDC. If you have an aftermarket harmonic damper it should have a scale on both sides of zero. Use the side marked BTDC.
Like the fellas said, it should be more like 12-18 degrees initial.
Larry
Old 06-17-2005, 08:19 AM
Thanks all for the quick replies..
They did install an after market balancer.....
Is this correct? It runs ok here
10---
---<=== current setting
0 ---
10---
20---
30---
Old 06-17-2005, 08:31 AM
MI2600's Avatar
Member# 3287
Usually on a timing tab it shows more degrees of advance than retard.
You have to be retarded (not you, the engine) now for the exhausts to be glowing.
Old 06-17-2005, 08:33 AM
k-star red is the smallest = 28
silver = 25
blue = 21
black = 18
I agree must be a vacum leak...do I fix the leak firts then deal with the timing issue after
Old 06-17-2005, 08:48 AM
The Headers glow at this setting.
---<=== headers glow at this setting
10---
0 ---
10---
20---
30---
Old 06-17-2005, 09:07 AM
Jmark's Avatar
You are going the wrong way on both selections!! Put in the black stop and then set your timing on the other side of zero at 16 degrees and go for a spin. You are setting the timing retarded (after TDC). Thats why its burning the headers.
With that cam, you need lots of initial timing. The black stop will limit the mechanical advance to 18 degrees,,,,, plus the initial of 16 will bring you to 34 degrees. You don't really need and vacuum advance yet until you know that everything else is set correctly.
Mark
10---
0 ---
10---
---<=====set it here!!!
20---
30---
Old 06-17-2005, 11:03 AM
timing
Jmark nailed it.......
Install the Black bushing.Shoot for the 16 to 18 initial. You are on the wrong side of zero. I cannot believe that it even runs there.......
Let the vacuum advance disconnected for right now untill you get it straightened out..
Keith
Old 06-17-2005, 11:05 AM
spinn's Avatar
jmark/kstar is right on. way to illustrate the point. do the headers still glow?
out in left field, it may be a tooth off also
Old 06-17-2005, 11:35 AM
Ok I have reset the timing as instructed however did not change to the black bushing I also have a 3000 stall converter and thought I need to have it come in at 36 degrees fast that is why I used the red bushing. should I go to maybe the silver?
Old 06-17-2005, 11:37 AM
spinn's Avatar
fast like 2000 rpm. use 2 light silver spring ,the balck bushing, 18 intial and 18 mechanical that = 36 total. vacuum disconnected.
18 is a little high (intial). listen to how the starter sounds. it may be too much for the starter. in that cases back it off.
Last edited by spinn; 06-17-2005 at 11:46 AM. Reason: use silver and blue for 2200RPM full advance
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 06:56 AM
SBC 350 Crank Balancer Problems bjam2 Engine 8 05-04-2004 07:36 PM
How to build a 350 insayne Engine 2 11-08-2003 07:14 AM
Finally decided on an engine build up! Adrenaline_Fiend Engine 2 10-20-2003 09:43 PM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
