Problems if I disconnect TCC wiring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2008, 11:40 PM
BMM BMM is offline
Hey guys. Theres a car I can get for a decent price, if what I think is wrong is wrong.
Car is a 1993 Grand Am GT, automatic transmission. Apparently, it stalls once it's hot/warm. I have done some research, and more often than not it seems to be the Lock-Up Solenoid is shot. By rights, if this is the case, once I disconnect the wires (theres a plug going into the tranny), the problem should be solved.
Would driving without the lock-up connected routinley create enough heat to cause an issue? Thanks guys.
Old 09-24-2008, 04:25 AM
SSedan64's Avatar
If it has the 3-speed trans I don't think it'll be a problem. If 4-speed you should change the lockup solenoid, do a filter/fluid change while you're at it. They are cheap $12-$20 at RockAuto. Filters as cheap as $6.
Old 09-24-2008, 02:14 PM
fast68's Avatar
likes chevy trucks & boobies
may be cheap for a solenoid but replacing it is the fun part
i always unplug them and call it good but if the vehicle is really super clean and low miles then you may want to have it fixed right
stuck tcc solenoid is very common issue on the 4t60e trannies
ive had to unplug many over the years due to stalling in gear at stop
good luck
Old 09-26-2008, 12:59 AM
BMM BMM is offline
Thanks guys. Ill look at the car soon as I can.
Starter problems - unknown wiring professor-patrick Electrical 3 10-09-2005 06:16 PM
85' corvette wiring problems AARRRGGGHH!!! WakBordr7387 Electrical 9 08-14-2005 06:32 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 12:03 PM
Tach's and wiring problem's 70 nova Electrical 2 03-24-2003 04:07 PM
