problems with my e-brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2009, 07:52 PM
Hi guys I have a problem with my e brake on my 92 f-150. my wife set the brake last night and it went to the floor and now the cable fell offf the back end and the brake is stuck on! how do I free the brake up and ultimatly fix the prob? thanx for the help.
Old 12-16-2009, 04:41 AM
have to take the drums off and replace with a new cable
Old 12-16-2009, 04:59 AM
S10 Racer's Avatar
http://www.warsprints.com
If the cable fell off and is loose, the brakes should be free. The E-Brake pedal ratchet mechanism is what holds the cable tight when the brake is applied. It may be that the cable is rusted somewhere along the line not allowing it to release. You'll play hell getting the drums off if the brake is set.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
94 GM Suburban Brake Problems DV8 Suspension - Brakes - Steering 3 02-02-2007 07:47 AM
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Brake problems... gemini86 Suspension - Brakes - Steering 5 10-06-2004 07:06 PM
