Not being there to see it, I can only offer these comments.
Ladder bars are a drag race only design. I am not sure what you mean by triangulated. Are they actually ladder bars, or do they pivot at the axle housing? Since anything mounted solid to the housing binds the suspension travel. Since your suspension is triangulated, a panhard bar is needed to resist side to side movement. When the suspension extends, the trianglulated bar arc makes the rear end move forward, and the panhard makes it move sideways. You will have to jack up the housing to running height to get everything to line up. I hope I shed some light onto the situation, at least enough to peak your interest in suspension design.
Thanks xntrik - problem solved, everything is in place. Tried to cut/paste a picture of the bars as seen at rjays.com web site (they call them ladder bars)but didn't work. The bars are not mounted parallel but have urethane bushings at front center pivots (so I called them triangulated) and adjustable clevises at the rear. Yes, I am interested in suspension and trying to learn. Any suggested reading material would be appreciated.
Something else - here's a picture of my panhard rod attachment. Between the mounting bracket is a washer, a Sears thread cutting die, a washer, the rod end, another washer. Any opinion on this. Also, how much lateral play should there be within the bracket. Thanks. |
To answer your question= I don't think there should be any "lateral play" in the suspension mounting.
Here's a place to start learning about the basic rear suspensions. Not all inclusive, but a good basic understanding. http://www.popularhotrodding.com/tec...ide/index.html Ignore it when he ^^^^^^^calls cylindrical bushings "spherical". Cruise the big magazine sites, PHR, HR, CC, SC, etc. and go to tech articles, and put "rear suspension" into the search. That should keep you busy all year... LOL The "resident" chassis engineer on this site is THE Billy Shope. Probably THE best chassis engineer anywhere, IMO. Watch for his posts or search for his posts in the history. Just enter BillyShope When he speaks...... listen veeeeery carefully. HotRod Magazine, current issue, April 2007, "The High and The Mighty", see p. 55 Last edited by xntrik; 03-05-2007 at 05:48 PM. |
| Ladder bars or what ? | triker | Suspension - Brakes - Steering | 6 | 03-02-2007 05:47 PM |
| Bolt in Ladder Bars | Hot Rod/SS | Suspension - Brakes - Steering | 1 | 07-02-2003 07:01 PM |
| definition of 4 link and ladder bar | mshanahan | Suspension - Brakes - Steering | 5 | 06-25-2003 08:52 PM |
| traction bars | corenele | Suspension - Brakes - Steering | 8 | 06-14-2003 01:37 PM |
| home made ladder bars | les | Suspension - Brakes - Steering | 2 | 02-01-2003 07:05 PM |
