Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems rebuilding 85 Iroc door hinges
Old 12-25-2012, 10:32 AM
MARTINSR MARTINSR is offline
To install the bushings you put a bolt thru the bushing with a washer on the top, put a socket over the other end against the hinge with the bolt going thru it and a washer and nut. Tighten the nut on the bolt and it pulls the bushing into place.
