Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems rebuilding 85 Iroc door hinges
  #18 (permalink)
Old 12-27-2012, 07:01 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Those are pretty cool malc.
Well I came up with something pretty cool and quick for the bottom hinge today,I was able to use the original half of the hinge that bolts to the jamb to replace the worn out half that was on the new door I picked up but the side that was welded to the door was so wore out something had to be done so I drilled it out larger to accept the large bushing so the pin dont wobble around I could have welded the pin but that would have made it hard to replace in the future..so now my bottom hinge has 4 bushings 2 for the pin and 2 where they should be....nice and tight...and no welding ...something anyone can do at home for around 10.00 a pair on the camaro...
