Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems rebuilding 85 Iroc door hinges
  #20 (permalink)
Old 12-28-2012, 05:47 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
The problem is theres no adjustment so when you change a door you have to bend the door and hinge until you get a good gap ..so If a pin wears out and someone bends the door to get it to close,when to change the pins and busings the door wont fit any more and things get a little tough,sometimes it takes two people hanging on the door to pull it back down,and then it goes too far down and you have to bend it back up again...
