Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems rebuilding 85 Iroc door hinges
  #22 (permalink)
Old 12-29-2012, 07:45 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Well here a couple pics of what I came up with,in the 35 yrs I've been doing this stuff This is the first time Ive ever done this but it works and it worked well too.I was able to squeek by ,replacing half of the top hinge but bottom one was welded to the door and was wore out bad so the pin just wodbbled around,I drilled it out and shoved a bushing in there now the bottom has 4 bushings...
I gotta thank old bodyman for turning me on to Oriellys for the pin and bushing set,I had givin up dealing with those yahoos the part # came in handy ,he just looked at me like how the heck did you know that hopefully someone will remember this cure if they ever run into this problem and it'll help them out..
ID:	70175   Click image for larger version
ID:	70176   Click image for larger version
ID:	70177   Click image for larger version
