problems removing leaf spring brakets - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 01:41 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
so i have an 81 Firebird that i am trying to install a set of shackles in the rear. right now its sitting on air shocks and thats what it keeping the fenders off the rear tires. been told that its really not good to have the body held up by the shocks. anyway so i bought a set of shackles off Ebay and went to install them the other day and i tried for almost an 2 hours to get the bolts out. i dont have a torch so cutting it out for me is not an option. and there isnt enough room between the brackets and quarter panel to get a good whack at it with a hammer....i know its a shot in the dark but i know someone has had this problem before, anyone have any advice for me??
Old 09-28-2010, 04:13 PM
BOBCRMAN@aol.com's Avatar
Longer shackles are a problem in themselves. Look at any of the sixties and seventies cars. Usually the lift you get settles down to near original with time and shackles cause handling problems if no rear centering bar is used..
Old 09-28-2010, 04:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would go with a different tire and wheel combo if i was you. JMO
I wouldn't use shackles But thats just me i use to though but that was back in the day as already stated. The right tire size and the right offset wheel is what you need. IMHO
Cole
Old 09-28-2010, 04:31 PM
chevykid90's Avatar
i dont really have the funds to get a whole new set of wheels and tires. nor can i get a new set of leaf springs. and i have had no luck in finding a local shop that can recurve my springs. the rear tires are 295/50R15 and are 12" wide. to keep them from rubbing when accelerating or turning i have to have at least 50 psi in the shocks, and the ride is terribly unforgiving.
Old 09-28-2010, 11:52 PM
ericnova72's Avatar
More for Less Racer
Without a torch to melt the rubber, you may be at this forever. The problem is that the thru-bolts have rusted and rust-swelled into the rubber. About the only other choice is to grind or cut the heads and nuts off the bolts with a grinder, or cut through the bolts with a Sawzall.
Rear leaf spring modifications! V8 Super Beetle Transmission - Rearend 1 03-24-2008 04:21 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
Rear Leaf spring kits greywulf Suspension - Brakes - Steering 2 03-06-2005 01:24 PM
Help removing rear spring on my 52 Caddy 52Caddy Suspension - Brakes - Steering 0 06-12-2004 05:10 PM
73 Camaro Rear Leaf Spring Replacment Problems mile-hightoyz Suspension - Brakes - Steering 1 05-14-2004 08:55 PM
