Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problems with rods on chev. small block
Old 01-09-2003, 04:32 PM
Larry Wilcox Larry Wilcox is offline
Red face Problems with rods on chev. small block
I have had a 305 chevy v8 bored .o3o over, the pistons were swaped on the origional rods, and now they don't line up square with the crank shaft. There is no twist, but the rods have probably been turned around on the pistons, or several were bent before the overhaul and the bearings or sides of the rods showed no signs of wear. What has happened and can I turn the notch of the piston towards the back of the engine and get dependable service from the backwards piston?
