Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
Old 10-17-2012, 02:40 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
What is the model list number stamped on the carb air horn?
stock metering blocks...or.
Pri and sec idle and high speed air bleed size? Primary and sec idle feed restriction size.?
Primary power valve restriction size.?
Use small precision drills or wire gauges to measure and gauge that with a dial caliper.
Think about getting some blower carbs. 650-750DPers
