Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
Old 10-17-2012, 02:51 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Where are these "air tubes"? on the side of carb body? or on the metering block? or on the carb baseplate??
72 is fine to start. You will need some jets to work with.
DO NOT START testing AT 14psi blower boost. 14psi is way too much for pump gas ...start at 5psi and work up.
