Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #47 (permalink)
Old 10-19-2012, 03:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I forgot to mention that if you had to dyno the engine w/o boost referencing the carbs, you can remove the PV and use a plug made to block the PV off. Jet the carb up about 7-8 jet sizes to compensate for not having the PV installed. This will work on a race-only engine or for a wide open dyno pull. On the street it will not work because the air/fuel ratio will be too rich much of the time.
The Following User Says Thank You to cobalt327 For This Useful Post:
mustang 671 (10-21-2012)
