Originally Posted by mustang 671
great , ok will tap the front secoundary metering plate to accept the jets . i do have a base plate below the carbs ( above the blower ) that have 2x allen key screws in the back ( facing the driver ) should be able to inject in there with water meth ?
I would not mod the blower carb adapter base plate. I'd leave that as is...I would use two 4bbl carb spacer style water injection plates (looks like a 4 bbl nitrous injection plate, or typical common 4bbl carb spacer)
Snow Performance is just one of many good Water injection system companies.
