hi guys .
had a great day today . finally got it to idle for a while at 950 - 1000 rpm. eventually it burnt off the old oil and mosture from the engine where it had been sitting . i have put 2x videos below for you to see .
i do have 1x problem still. my neddle valves get stuck every now and then . i have set them, to just show the fuel level at the sight plugs . but sometimes while its running and i turn it off the electric fuel pump carrys on pumping fuel and out into the carb and out of the breather tube. hopefully its just a sticky needle valve, will replace them next weekend and see if that fixes it .
i am getting there now. i also jacked up the back and ran the trans and got around 6 litres of dex 2 atf oil in the c6 auto box. does that sound about right ?
cheers again
