Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #75 (permalink)
Old 11-04-2012, 03:37 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
Originally Posted by F-BIRD'88 View Post
If you had low 5psi boost you could do this different....But you don't.
you need to cut those ugly carb choke horns off too.
cheers . will speak with the dyno guys as they have pv blanks and the higher jets. i am running around 11 psi which is better than what i thought at 14 psi . i do have a blower snout which is the retro looking one. is there any reason for cutting off the carb horns for any better set up ? or just coz you think they are uglily ? they will be covered by the blower snout anyway so wont be seen , i just dont put it on when running so i can see the boosters etc to make sure the needle valves have shut off
