Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #86 (permalink)
Old 11-11-2012, 10:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by mustang 671 View Post
hi all . had the engine running for a while today . sorted out my brakes but my alternator still isnt charging.
however the car didnt want to start when hot . and i got a back fire through the exhausts ( not the blower - that never happens now ) as i have a wasted spark system im thinking my mixture is too rich ??
am sure this will be sorted when im off to the dyno and they plug in their lambda sensors.
any ideas ? i didnt pump the throttle. went to catch a couple of times but nout . all good from cold . just when its hot
expect the pv will neede to be changed .
cheers
If you wire in an ignition interrupter, that will help the hot start problem.
It works by allowing the engine to be spun by the starter, w/o the ignition enabled. Then after the engine is spinning nicely, the momentary switch is released allowing the ignition to become hot and the engine fires.
The Following User Says Thank You to cobalt327 For This Useful Post:
mustang 671 (11-11-2012)
