Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #94 (permalink)
Old 11-11-2012, 04:20 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
ok i get the picture , yes i did start it with a couple of pedals then once it caught i held it for say 30 secs then i let it idle. so i will hold it and let it warm up in the future.
the running in oil and filter have probably had only 10 minutes of use at the most .
the reason why i ask is - do you think the millers running in oil is ok for the first dyno session or would you reccomend a more conventional oil. i like the idea of the rings bedding in quickly and not having too much lubrication , the guys at the dyno said once its fueling correctly they can run it in over a few stages over a 30 min period and run it in,
they then said it would be normal practice to change the oil once i have been to the dyno .
