Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #96 (permalink)
Old 11-11-2012, 04:45 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
When the engine is hot...like on a restart...you should not need to pump the gas.
CLOSED throttle..ALWAYS . Use the ignition interupt toggle switch.....crank it, 1-2-3 count and throw the spark switch on ,,,. fire it up and then rev it, to clear it. Clear it ,, then let it idle.
Real simple.... No computer required.
Computers are for porn searching.... even in Spain. Didn't any body tell you that?
