Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #99 (permalink)
Old 11-27-2012, 05:40 AM
ProStreetRob's Avatar
ProStreetRob ProStreetRob is offline
5.7L S10 LS SS
Originally Posted by mustang 671 View Post
Computers are for porn searching.... even in Spain. Didn't any body tell you that?
sounds like you have a nice selction of toys there . i would be interetsed in your 351w spec ?
Nothing wrong with a little Hot Babe porn and I do agree with you about computers, NOTHING is worse than being at the mercy of a Tuner
I probably felt different when my old 00 Lightning was running 9's at 140 MPH and I was driving it to and from the track but I have friends that give up their vehicles for 6 months to get tuned and that is absolutely INSANE and unacceptable. I bought this Lightning mostly as a tow vehicle and also to have a fun vehicle to drive more often. The Sierra only comes out on the SPECIAL DAYS.
The set up is nothing to crazy, just a fun performance truck I can drive anytime and anywhere and also do some towing
1993 Ford Lightning
High Output 5.8L w/high-silicon aluminum hypereutectic pistons 8.8:1
Hydraulic flat-tappet camshaft, duration is 260 degrees intake, 274 exhaust
Aluminum Trick Flow Heads
Scorpion Performance Roller Rockers
Kenne Bell 2.2 Blowzilla Supercharger
Kenne Bell Boost-A-Pump w/ In Cab Control
Accufab 75MM Throttle Body
Pro-M 92MM MAF
Ford Racing 30 lb Injectors
3.5 Cold Air Intake System
Built E4OD Transmission
8.8 Rear 4.10 Posi
MSD Boost Timing Master Control (#5462) w/ In Cab Control
MSD Street Fire Coil
Late 90s Bronco Computer (302 E4OD)
Bassani Equal Length Headers
Bassani Off Road X Pipe w/Cat Delete
Bassani Cat Back w/ (2) Side Outlet Tips
Looks pretty dam good for a 20 year old tow vehicle
And I can make all the adjustments I need to by simply turning a couple of knobs
