Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #119 (permalink)
Old 12-14-2012, 11:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by mustang 671 View Post
cheers cobalt . just what i needed to know . will get some ordered up for after the dyno .
some say its worth taking a oil sample and having it sent off to analysis to see what if any other chemicals have got into the oil . too much fuel . water etc
good idea on first dyno run ?
I've never done this, but it couldn't hurt. I tend to rely on doing thins as best I can and then leave it in the laps of the gods.
The problem I would have is not knowing how much of any element would be normal vs. abnormal. That info might be supplied by the testing facility or somewhere online. The bearing type/materials and the other things like piston alloy, etc. should be known to see if those elements showed up, but the amounts of these elements in the sample (PPM?) would be the stumbling block for me.
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
mustang 671 (12-15-2012)
