Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #140 (permalink)
Old 04-27-2013, 03:25 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
hi all .
as im supercharged where to I get the correct vacuum reading from to measure the highest vacuum when adjusting the air mix screws ?
I have a take off under the primary bowl at the base of the carb
I have a take off on the plate under both carbs that mount the carbs to the blower.
then finally I have a available vacuum take of in the inlet manifold.
which one ?
cheers
