Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #146 (permalink)
Old 04-30-2013, 02:28 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Hard hot engine restart:
Install and use the simple ignition power interupt switch.
Verify the quality of the battry cables and clean connections at the battery/starter solenoid and starter motor
AND THE ENGINE grounds.
Install the ignition interupt switch and lock out the timing. full timing at idle. No advance curve.
Fixed timing 28-32deg for now..
May have to play with the exact primary and secondary throttles idle position bias (T slot exposure) a bit to get it exactly right.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
mustang 671 (05-02-2013)
