Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #166 (permalink)
Old 05-06-2013, 02:48 PM
metalstorm metalstorm is offline
What spring do you have in the vac secandery of the carb?On the pri side if the power valves givee you problems you can square jet to get past that point untel later by going 6/8 jets up from with the pv's.
