Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - problems with running my supercharged 351w
  #167 (permalink)
Old 05-06-2013, 03:16 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
Originally Posted by metalstorm View Post
What spring do you have in the vac secandery of the carb?On the pri side if the power valves givee you problems you can square jet to get past that point untel later by going 6/8 jets up from with the pv's.
i am sure it is the purple one but will double check.
i have what looks like a orangy brown cam for the acc pump shot. but looks more a dirty orange than a dark brown.
primarys 68
secs 78
shoters have a preifx of "R107" on all of them
10.5 pv.s
the acc pump shotters spray a good jet of fuel in them. will find out what prefix is on them.
i tried to give it a bit this weekend but it seemed to not want to get off. either its a very slow throttle response > blocked fuel passage but on the idle circuit it revs fine out of gear. only when load is applied. . wasnt a bog. just seemed like there was no umpff
i got around 16 hg vacuum at idle last time i checked.
