problems with running my supercharged 351w - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 11-02-2013, 10:29 PM
ProStreetRob's Avatar
5.7L S10 LS SS
Originally Posted by mustang 671 View Post
how did you get on ??
I agree its 11% underdriven . what's your thoughts on going 1 to 1 ?
haven't a clue on dyno or sae numbers etc. suppose I thought its their job to do all of that ? give me some pointers to ask them ?? the dyno works the opposite to a alternator and uses electric current to operate . does that help ?
they did say that you "yanks " lol . do inflate dyno numbers ?? ie the bhp over there is different to here ? I know that seems mad and I don't think they mean its a different value . for example, they had some dick head who had a corvette and he raved that it was a 500 bhp car. the most the dyno saw was 375 . now that could of been 500 bhp at the fly wheel ?
think they have just had a few big v8s go in there saying this and that and when it comes down to it the power isn't there.
they like the idea of my water inj. said to get it as good as it can then slightly back off and use water inj to add some intercool charge.
have heard that methanol rots alu ? failing me getting a refrigeration coil put into the tank what other liquid can I use with water to provide intercooled effect ? I read somewhere on here windscreen wiper cleaning liquid -screen wash ???? really ??
what boost you run with blown engine ? what comp ratio ?
The track was bad today, we had 2 rain delays, 2 MASSIVE OIL DOWNS, and I spent probably an easy 4 hours sitting in the staging lanes
Deep Staged by mistake on the first pass and ran a 10.92, then ran a 10.81 and the best ET of the day was 10.70 (it went 10.66 & 10.61 at Atco earlier this year) Atco is a much better track and closer to sea level where Island is up in the mountains at higher elevation so I guess I cant complain since we took it home in one piece
As for the Street Beast, my Sierra makes crazy power so I dont need much boost. I'm running a 56 T Upper Pulley + 52T Lower Pulley =’s 8 lbs of Boost @ 6,000 RPM (-5.5 Underdriven). At that set up the compression correction works out to 13.1 Compression. If I switch the pulleys around it's 12 lbs of Boost @ 6,000 RPM (+5.8 Overdriven) With that set up the compression correction works out to be 15.1
Mine sounds totally different than yours, I made this a few days ago on my phone. Just a little put put around town...
A few pics from the track today
ID:	95377   Click image for larger version
ID:	95385   Click image for larger version
ID:	95393   Click image for larger version
The Following User Says Thank You to ProStreetRob For This Useful Post:
mustang 671 (11-05-2013)
  #167 (permalink)
Old 11-03-2013, 11:53 AM
bentwings's Avatar
bentwings
Somewhere above you were talking about the boost not being what the charts showed. It's possible you have a small case 6-71. Not a problem but you just have to spin it faster. Hopefully your blower is not messed up. I've run into at least 6 this year with too little clearance on the rear of the rotors resulting in a galled case and rotors.
Since you can't change the bottom pulley the only choice is the top one. You may have to make a spacer under the blower. 1/8, 3/16 and 1/4 in are common SAE sizes. Adjust for metric material if you need to. The reason for the spacers is that you you may run out of room for adjustment on the idler.
The Following User Says Thank You to bentwings For This Useful Post:
  #168 (permalink)
Old 11-05-2013, 01:14 PM
mustang 671's Avatar
hi pro street rob
the sierra sounds nice on the rd. and congrats on those times. must be hard when its raining. here in the uk the weather has turned so don't expect I will be getting out much for a few months, prob not a bad thing. try and get some nice cold dry days and put some miles o it before the summer heat comes. less chance of it getting too hot. your pulley sizes are interesting. seems the charts aren't any use and just a very very rough guide.
  #169 (permalink)
Old 11-05-2013, 01:16 PM
hi bent wings.
thanks for the comment. I can get a different size belt so haven't got any issues with the tensioning luckily. that's interesting you mention it could be a smaller case blower. will look into that. ta
also I looked at my blower before I brought it years ago and also more recently when I o-ringed out the inlet manifold. the rotors are good. no scores. no leaks from the blower either.
  #170 (permalink)
Old 11-05-2013, 01:38 PM
hi all and those just following . I really could do with some input on the following. and I know it may be a wet finger in the air and hope ????
so currently I have a 45 tooth bottom and 51 tooth top pulley. I got 7psi at 6000rpm but had so much more to go and only produced 330bhp.
have spoken with the dyno guys again today and also a supplier over your neck of the woods who can supply me with a 42 tooth cog for $115 + delivery which isn't bad. my questions is , can anyone hazard a good guess- work out? how much boost that would get me to ? so 45 bottom and 42 top
my engine started at 7.48to1 comp ratio but since then I have changed from a felpro normal head gasket to a felpro mls one. nothing else has been changed apart from it being homed out just slightly and a bit of piston to bore wear but prob nothing to be honest as the engine hasn't had much use. the orginal block is 30 thou over and I have kb hyper pistons - but I do now have a new crane custom grind cam which I posted about earlier which is a roller cam.
I have large headers which collect and go into 3" exhausts . under and out the back. the car was for racing before I imported it so it has a large dual exhaust.
I have a c6 with a high stall b+m torque converter. Been uprated with reverse manual shift pattern body.
my thoughts are that the combi would give around 10-12 psi ? which would be a lot better , I will have the water inj running with this higher boost. I can easily get hold of 99 octane fuel to use. only 5p a litre more . but still bloody 6.58 a gallon
help !!!!!!!
  #171 (permalink)
Old 11-05-2013, 01:46 PM
Originally Posted by F-BIRD'88 View Post
The "eddy current" type dynos give the most conservative power numbers.
Transmission: There is more to it than just fluid level.
High stall converter efficiency.
High /direct clutches.
Tire slip. Tire distortion on rollers.
Exhaust
hi fire bird.
have just posted below my auto c6 spec. its all new and good quality stuff.
tyres are brand new. they sprayed some goo onto the rollers for it to grip.
the exhaust I also mentioned. but agree if it had a stainless all the way through im sure it would flow better. but it is big bore . and I have nice long headers. large bore aswell.
  #172 (permalink)
Old 11-05-2013, 01:50 PM
Vacuum secondary throttles opening?
yes they re fine
  #173 (permalink)
Old 11-06-2013, 02:35 AM
Yes they are opening fully . Pri jets 72 second jets 78 did change secoundaries to 82 but no power increase just highest air fuel mix .ign mapped by dyno guys for peak bhp . Gave it what it wanted . Needs more boost . Any ideas on pulleys ? Fuel prressure maintained .
  #174 (permalink)
Old 11-06-2013, 08:14 AM
No point . As the 1/4 mile track is 3. Hrs from me . Dyno wouldn't be that far out -ie 150 bhp more is still only. 480 bhp . Which is where I wanted to start from . 550--600 bhp is more than do able with what ive built . Eveerything is new . All readings at dyno where good . Have plenty more to go . Need more boost . Some. Standard 350s are making this power,
Need help on pulleys if you can ,
Point taken though and I will go to the track . Once im seeing more power
  #175 (permalink)
Old 11-06-2013, 09:08 PM
5.7L S10 LS SS
Believe me 671 I can relate on not having a local track They closed each and every track within a 100+ miles of my house and sometimes for me it's a 2 day routine to simply go make a few passes, it's a real pita...
BUT IT'S WORTH IT WHEN YOUR THERE AND DOING IT
Here's my passes from Sat, make no mistake these 351w can kick some *** when they're making power
  #176 (permalink)
Old 11-12-2013, 02:32 PM
10 92 Island 11 2 13 - YouTube
10 81 Island 11 2 13 - YouTube
10 70 Island 11 2 13 - YouTube
hi rob. wow. they are great , bet your happy with them.
I am getting on with my engine. seem to be going around in circles on here. I cant change my bottom pulley. so I have to change my top each time I want a boost change. am thinking of ordered up a 47 and 43 top pulley but waiting for the blower shop to get back to me on expected boost based on what I have told them with my engine figures and current blower sizes.
prob go back to dyno over xmas. I like the dyno for testing out. more safer and controlled rather than hoping and screaming down a track. I will do that when its set up.
  #177 (permalink)
Old 03-07-2016, 01:48 PM
Hi all. Got the car sorted. All seems happy
The Following User Says Thank You to Mustang671 For This Useful Post:
64nailhead (03-08-2016)
351W won't stay running in gear Fairlane351 Engine 2 05-17-2010 01:10 PM
Cooling problems with 502 Supercharged motor firstgear Engine 24 05-19-2009 11:17 PM
Supercharged 351W advice requested rodderforchrist Engine 4 03-21-2007 03:10 PM
Supercharged Fuel problems drewbe Engine 38 08-20-2006 08:48 AM
351w won't stay running help! llane915 Engine 8 11-27-2004 04:47 PM
