this are the timing figures i have at the moment . they need fine tuning but are getting it ideling at 850-900 rpm which im happy with . especially with the lupmy cam i have .
So is your buddy going to bring you back some shiny new Holley 750HP Blower carbs?
That cam is not "lumpy" Thats a sissy cam..LOL You ar choking that poor blower motor with that tiny cam. |
no not at this stage. i like the vac sec on a blower , as the blower can decided when they come on and i get better mpg around town etc. once dialled in they will be fine ,
regarding the cam , i specifically got this crane "supercharger cam " from them as it was a good moderate to fair ride cam for my set up. i didnt want a mad unrelistic cam. dont agree i am choking it. yes i agree there are bigger duration higher lift blah blah cams out there. but i want a reliable daily driver not some unrelistic strip car. i have contacts in the film industry and concierge so i do want to use it commercially . something that would be more uncomfortable with a big arse cam. again a matter of opinoin and not fact as are alot of mods on cars. did you have any thoughts on my question earlier on my c6 oil capacity with a front mounted oil cooler ? cheers shaun |
You are quite welcome, Shaun. I'm still following this thread and will add when appropriate. I'm sure you'll get this sorted out and before you're done you'll be driving a BEAST!
Mark |
Been following this thread and learning a lot
Hope you get it all worked out 671 and I have to agree with that cam not sounding to lumpy, hell mine fires like once every few seconds ![]() I also have to agree with the sideways carbs, they fit and look quite well if done right, here's mine ![]() Unfortunately you really cant hear the motor in that Best Of Luck and hoping to hear you got it all figured out shortly |
| The Following User Says Thank You to ProStreetRob For This Useful Post: | ||
mustang 671 (11-07-2012) | ||
hi all .
been working on the car again today . so i pumped twice from cold. choke off secound turn of the engine and off it went. kept it for 1500 rpm for a moment and then it happily idled at 900 rpm. looking forward to the dyno in a coulpe of weeks . i will jump to another subject concerning my brakes. and will come back to you all when i get some updates after the dyno and i hope to get a video and some figures for you !! last question until i come back to you. currently i have millers running in oil. and i have now had the engine running and idleing for a bit. whats your opinions on keeping this oil in for when i go to the dyno ? i am in the mindset of running in the engine quickly and not over 1500 odd imiles as most stupid manufactures advise. bed the rings in quick under load before its too late. i have seen the evidence to make my mind up. so with that said would you recoomend this oil as it will alow this or a semi synthetic as the running oil i have is mineral !! cheers all - and amazing advise. |
hi all . had the engine running for a while today . sorted out my brakes but my alternator still isnt charging.
however the car didnt want to start when hot . and i got a back fire through the exhausts ( not the blower - that never happens now ) as i have a wasted spark system im thinking my mixture is too rich ?? am sure this will be sorted when im off to the dyno and they plug in their lambda sensors. any ideas ? i didnt pump the throttle. went to catch a couple of times but nout . all good from cold . just when its hot expect the pv will neede to be changed . cheers |
It works by allowing the engine to be spun by the starter, w/o the ignition enabled. Then after the engine is spinning nicely, the momentary switch is released allowing the ignition to become hot and the engine fires. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
mustang 671 (11-11-2012) | ||
that sounds a good plan . as i havent been to the dyno yet i hope it will be just a fueling and timing issue slightly off ?
also is this normnal on a blown motor ? do they suffer from this ? i have 1x stage colder plugs than normal |
You can take a good look at the plugs to see if they show signs of fouling. I wouldn't call it normal, at least not for a sorted out tune up. But seeing as how you're just beginning to get a handle on this, I'd say it wasn't that unusual. Especially if its only been idling and no real load/heat put on it. Before changing anything on the tune up, try the interrupter first. If you still have the same issues then you can get further into it.
It likely backfired thru the mufflers cause yu keep letting it idle slow, when cold.
(this allows unburned fuel to enter the exhaust system) 2000+ rpm when you first fire it up. Keep the rpms WELL up until some heat gets into the blower. its not a taxi cab. Blower motors need to "warm UP" The simple dash mounted ignition power interupt toggle switch will allows easy cranking/starting when the engine is hot. The vac sec carbs are not the best for the blower motor and will not save you gas or do any of the other things you think they will. Double pumpers work a lot better. Preferabily Holley 750 blower carbs with boost referenced power valves and 4 corner adjustable idle circuits, set up specificly for a roots blower. + down leg boosters and adjustable idle and hi speed air bleeds. You will only getr so far with those carbs on it. They are not blower carbs. Change the plugs, oil and filter before you go to the dyno session. Bring extra spark plugs and good fuel with you. bring holley carb gaskets, etc etc. coat all carb gaskets wth vasoline or PAM cooking non stick spray so they don't stick and you can reuse them. if/when you idle the engine in the garage, it is rebreathing its own exhaust gas and will load up and foul the sparkplugs. Blower motors need to be driven, not idled. Last edited by F-BIRD'88; 11-11-2012 at 12:34 PM. |
Be aware your pump gas is no better than ours here. Different rating standard.
Your 98 octane pump gas is research method only. Ours is R+M/2. (92-94) Yours is 92 at best. Go easy on the spark advance, on pump gas. If you want to see how much power it can really make use 110+ unleaded racing gas. Now you can put some timing and boost to it. Do not confuse the two different tuneups. if you are going to run it with a blower scoop on, get rid of the choke horns on the carbs. Other wise the air fuel ratios will be a lot different when you are driving it with the hat on. you will have wasted your time dynotesting . Tear down the carbs and do them right, before the dyno test. Cut the choke horns off and boost reference the power valves and make sure the vac sec system is A-1. It will run a whole lot nicer with the powervalves functional and properly boost referenced. Until that is done don;t expect it to drive nice. Expect short spark plug life and a bockey engine. Last edited by F-BIRD'88; 11-11-2012 at 12:38 PM. |
| 351W won't stay running in gear | Fairlane351 | Engine | 2 | 05-17-2010 12:10 PM |
| Cooling problems with 502 Supercharged motor | firstgear | Engine | 24 | 05-19-2009 10:17 PM |
| Supercharged 351W advice requested | rodderforchrist | Engine | 4 | 03-21-2007 02:10 PM |
| Supercharged Fuel problems | drewbe | Engine | 38 | 08-20-2006 07:48 AM |
| 351w won't stay running help! | llane915 | Engine | 8 | 11-27-2004 03:47 PM |
