| The Following User Says Thank You to ProStreetRob For This Useful Post: | ||
mustang 671 (12-12-2012) | ||
Mustang 671, in watching this thread, I think that F-bird is just trying to make sure you are aware of some of the stuff that he has knowledge of. I have not seen anything he posted that was not correct. You have a lot of "bells and whistles" on your rig that, for sure, will create a bunch of headaches and destroyed parts if not careful. The "hyper vs. forged" decision is liable to give you pin bosses pulled out of the pistons, seen too many of them happen that way. And a huffer will really put lots of heat into the crown / ring pack area, adding to the problem. He suggested changing the oil, most likely because it sounded like the raw fuel has most likely gone past the rings and thinned the oil. Look . . . . , nobody wants to see you have problems with your ride. But you seem to be sort of hard-headed to fixing the possible issues you are seeing. So . . . . . just how far of a road trip is this Spain you write of??? Take care, K |
There are differing opinions on how to break in an engine and the debate has been going on since the Model T was new. You have Keith Dyer posting to your thread. Take advantage of the opportunity- there's no one who could answer your questions better.
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
regarding the oil- again that was took incorrectly. i have only recently changed the oil as i had a big over fueling issue and wrong timing , so i ditched the oil and filter and replaced it with millers running in oil . my question on that was -- is millers running in oil ( ie forget the brand - its a mineral based running in oil ) ok for taking to the dyno for them to tune and do a bit of running in. seems silly to ask as its called running in oil. but wanted some opinions on it ?? trust me im no hard headed dude , quite the opposite, i am a carpenter/builder. i have built the whole thing myself using different people to make , weld , design and fit bits to get to where i am . eveyone thought i was mad and alot of people said it wouldnt work etc . but its running and its finished , however i am no fool and know the serious part is the engine tuning running in and to keep det at bay . regarding the running in . i personally have a good friend who builds and tunes gp250 track bikes 2 stroke and 4 stroke super bikes . he also agrees that he preferes the method of cuttting in the rings as quick as possible and not to run in a engine as manufactures reccomend, ie 1000 or so miles , so when i go to the dyno i am intersted on peoples opinions of the dyno guys saying they can load up the back wheels and run the engine in for 30 mins or so. whats your thoughts? thanks shaun |
i know of one engine builder who put a polishing compund down a bore on a mclaren m1 engine before a race as they wouldnt of been able to of raced it as that bore was low on compression. it fixed it for the race, its also the same car from your neck of the woods . 1960s mclaren m1 my client has recently bought it. chassis number 1 of 66 , it started some first race in 66 over there aparently. nice motor . has a 350 chevy in it. |
Actually the engine could be broken in on the dyno. But if you choose to drive it to do the break in (I see nothing wrong w/that, I have done it since day one), be sure to use engine braking to slow the car after running it up. This helps the process.
Good luck and I hope it performs on the dyno as good as it looks. |
mustang 671 (12-13-2012) | ||
i will be trailering it to the dyno as its not road legal yet , and also agee its better to have it broke in a bit on the dyno . i do get worried about the lack of air flow and pressure that the dyno cannot replicate , at 60 mph the air flow and pressure surley will make a differnce compared to the usual fans they use . i am lucky where i have the ecu so we can plug the lambda sensors in and also do a road test and to see whats going on with the air / fuel mixture on the road . thanks for your help . whats your thoughts on the running in oil ? would you go with it or change it for a semi synthetic type ? cheers |
Damn! no new posts!! Congrats to f-bird for his patience on the matter! Good thing 'stang ain't no "hardhead"!! Oh and Keithdyer... I think you nailed it!! Good luck on that beautiful stang dude!! (should have just put 2 blower 750's on and been done with it!!) But then I wouldn't have had the fun of reading all this! One more thing... Holy crap!?!?! that is a GIANT top blower drive gear!!! Guessing the bottom one is relative!! Lets see some more pics!
yep got that re the choke horns .
re the top pulley . it is larger than norrmal due to the way i have had the bottom pulley specially machined to cover my harmonic balancer ( rattler ) i didnt like the way people bolt a pulley to the front of a balancer then go on to say you have to double key way it. blah blah. no s**t the amount of strain and fource to spin the blower with a pulley stuck to the front of the crank is utter madness to me. so i simply had one specifically machined to fit snug over the balancer . this in turn made the top pulley the size it is to get the psi i am aiming for. i dont want dp carbs , opinions vary on that side of it. some like dp some like vac secs, dont think its a case of saying this is what you should use . it depends on what you are using it for. street - race - strip etc etc, i like pat ganagl opinion on blown supercharging for the street , he aint daft . once i been to the dyno i will post some pics for sure . back to the last question - whats your thoughts on the oil choice for a dyno run ? |
Once the engine is broken in you do not need as much additives as you did during the break in process. That's why they sell break in oil and oil to be used AFTER break in. You can use the ZDDPlus-type additive to duplicate these same amounts of additives when using regular motor oil. This has been written about extensively, if you do a search here or on the net you'll see plenty of info on ppm of additives needed for long term use, etc., so I'll not rehash it all here. |
mustang 671 (12-14-2012) | ||
cheers cobalt . just what i needed to know . will get some ordered up for after the dyno .
some say its worth taking a oil sample and having it sent off to analysis to see what if any other chemicals have got into the oil . too much fuel . water etc good idea on first dyno run ? |
![]() The problem I would have is not knowing how much of any element would be normal vs. abnormal. That info might be supplied by the testing facility or somewhere online. The bearing type/materials and the other things like piston alloy, etc. should be known to see if those elements showed up, but the amounts of these elements in the sample (PPM?) would be the stumbling block for me. Good luck. |
mustang 671 (12-15-2012) | ||
will ponder on that one hmmm |
| 351W won't stay running in gear | Fairlane351 | Engine | 2 | 05-17-2010 12:10 PM |
| Cooling problems with 502 Supercharged motor | firstgear | Engine | 24 | 05-19-2009 10:17 PM |
| Supercharged 351W advice requested | rodderforchrist | Engine | 4 | 03-21-2007 02:10 PM |
| Supercharged Fuel problems | drewbe | Engine | 38 | 08-20-2006 07:48 AM |
| 351w won't stay running help! | llane915 | Engine | 8 | 11-27-2004 03:47 PM |
