Problems starting fresh engine up for first time - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 09:51 PM
ok so today i was trying to fire up the motor for the first time been stressing hard for a couple hours NOW ok so every time i crank it its back firing no matter how i turn the distributor retard or advance it back fires and carb goes in flames the motor is a sbc 350 turned 383 the thing is it has domed pistons should be at 11 something with the compression the fire order i have now is 18436572 can any one please shine the light on me i am seriously going to set this ****ing motor on fire i know im probably missing some info
Old 04-05-2013, 10:02 PM
Proud LOSER
Plug wires mixed up, or dist off 180
Old 04-05-2013, 10:06 PM
i doubt it because before i had the distributor pointing at cylinder 1 at tdc
Old 04-05-2013, 10:15 PM
Proud LOSER
And where were your cam and crank dots situated when you installed it pointing at #1?
Old 04-05-2013, 11:12 PM
spinn's Avatar
The tdc mark can indicate tdc power or turn another 360 for tdc exhaust.
You want the rotor pointing to number 1 on cap tdc compression. Both valves closed.
Old 04-05-2013, 11:30 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
I'm going to give you the best advise yet.This is without a shadow of doubt a timing issue.Unless your willing to accept the help given.................what's the point??.
The Following User Says Thank You to 1Gary For This Useful Post:
Richiehd (04-06-2013)
Old 04-06-2013, 06:52 AM
thegrandprixsniper, The best thing to do is to start over and find TDC. Pull the drivers side valve cover so you can watch the intake and exhaust valve on #1 cylinder. Like stated before when the line on the harmonic balancer is lined up with 0 on the scale both valves will be in the closed position. Remember when installing the timing chain gear set you set the crank dot at the 12:00 position and the camshaft dot at the 6:00 position. The #6 cylinder is ready to fire so drop the distributor in with the rotor pointing to #6 spark plug wire on the cap. You can also turn the crank one revolution where the crank dot and the camshaft dot are at the 12:00 position and drop the distributor in with the rotor pointing to #1 spark plug wire on the cap.
Old 04-06-2013, 12:04 PM
thanks allot for the replys and yes the marks one the timing gears where pointed at each other at 6 and 12 o clock position but im just going to start from the beginning and watch for the valves and re do the dist again but seriously thanks for the help ill let you know how it goes
Old 04-06-2013, 12:47 PM
To make it easier, if you are pulling the distributor out anyway, slip the dist cap onto the body and line up the No. 1 plug tower straight down to the dist body and put a black felt mark at that spot. Then after the cap is off transfer that mark to the top of the edge of the dist body. That way when you drop the dist back in you are able to line up the rotor with the mark once the distributor is fully seated. If you would like a little advance set into the dist rather then TDC, at this point you can turn the engine to lets say 8 to 10 BTDC for example and set the felt mark on the dist to line up with the rotor, and then snug down the clamp. Retrace all wires again just to make sure nothing was overlooked and you have a couple of wires crossed etc
It might not hurt to have a fire extinguisher sitting there at the ready too as per your last fiery attempts !
Old 04-06-2013, 12:58 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Why pull the distributor? Just relocate the wires on the cap its easy and quick! #1 doesn't need to be in any specific spot! The # 1 plug wire only needs to be where the rotor is pointing at when #1 cylinder is at compression TDC!
Jester
Old 04-06-2013, 01:15 PM
You have a very good point there Jester !, I am now more used to an engine where everything is made to be in a particular spot because of all the rear high tension lead wiring harness clips behind the engine and doing that once is bad enough LOL. A wires over the valve cover traditional style engine compartment is so much easier to work on.
Old 04-06-2013, 01:57 PM
Richiehd's Avatar
JS-70
Yeah...you are 180 out. Pull plug #1 bump starter over until you feel compression come up. Turn to timing mark TDC, drop dist. in on #1. Every first timer on this site has made that mistake.....once.
Old 04-06-2013, 04:10 PM
GMC boogie's Avatar
Cam and crank dots must both be at 12 o'clock to stab distributor with rotor pointing at #1
problem
Engine starting problems malibooguy71 Engine 2 05-26-2012 08:06 PM
still having engine starting problems Brandonion1985 Engine 3 05-16-2011 10:13 PM
Engine starting problems, Mopar Steves66 Engine 15 03-18-2006 03:05 AM
First time starting engine 70GMCPICKUP Engine 2 10-13-2005 11:14 PM
new engine starting problems... Sagacious Engine 9 08-11-2004 05:24 PM
