problems with a t400 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Old 08-27-2008, 06:31 PM
so,i end up w/ a recently pro built early 70s t400,many mods,welded sungear,and output carrier assy,,removed front band and servo,1-2 accum has its o-rings out,(this is all manual valve),no gov,circuit tubes gone,and plugs in its place,useing a shift kit w/ 1 checkball,#5 position been drilled,others r capped,uses #4 checkball,could use #3 according to seperator plate,a 3/16" spacer was installed between the 1-2 shift valve and 1-2 modulator valve,the center support assy is missing the second metal sealing ring,half the intermidiate clutch springs r missing,missing 2-3 accumilator piston cup and spring.This car has 650 horses in the motor,i need to get it right,came in w/ a burnt direct clutch pack,but,burnt funny,like 1/4' flat pieces are shedding(burnt)from the disc faces,all except the disc side faceing the metal at the pressure plate,looks new.i was thinking maybe this pack rode because of being too tight?theres no 2nd gear in this trans,,thats complaint.it has a heavy sprag that mounts to back of center support assy,and reaction drum /input carrier,i can find no spec as to which way this should turn,wish i knew,maybe this is cause of all?any help would be appreciated,cant keep this car much longer,im swimming,also has poor design on mounts,takes half day to remove it,ide like to install this once.
    Advertisement
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-03-2008, 06:56 PM
k.its fixt,the checkball placement paper my trans jobber sent was wrong,,,yes wrong,they had it listed as useing 1 of 2 possibilties to change feel of shift.this unit had a restrictor cap in the reverse hole that mates to reverse in the center support,in that cavity went the checkball,,trans uses no 1-2 acumalator seals,if this isnt blocked it will slip in the direct clutch,and burn it fast.car wheel stands now in 2nd and 1st no problems.and that spag thats on the center support turns counterclock,not clockwise,looking at it from either way(flipping over).so hey,i swam,i made it to shore,is ok tho,gawt another brain twister posted about a landrover.someone throw me a lifering plz
Recent Transmission - Rearend posts with photos
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Hot Rod Forum : Hotrodders Bulletin Board forums, you must first register.
Please enter your desired user name (usually not your first and last name), your email address and other required details in the form below.
User Name:
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 05:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
