problum with shifter
i got an 81 camaro and with the stock shifter but i am haveing problems because when i **** park is were it is suppose to be but reverse is in the neutral position and neutral drive so forth i cant figure out why can somebody help me?
check cable mounts , there is an adjustment on the shifter it's self under the center consul cover
At the Bonneville Salt Flats, first gear is known as 130 mph. |
i cant find any adjuster on my shifter under the consule and the cable isnt adjusble any other way the i can see.
adust the shift cable under the center console like he said
its there, pull the entire console off, not just halfway, you'll find it. it's pretty easy to adjust, put it in park, slide the adjustment all the way back, tighten it, then go through the gears. then slowly adjust out until it's right. |
| Muncie shifter adjustments needed? | Jims64 | Transmission - Rearend | 2 | 12-21-2004 11:01 PM |
| Hurst Street Rod Shifter | Sweet-34 | Transmission - Rearend | 0 | 11-03-2004 06:47 PM |
| Automatic shifter in pickup floor? | newchevyman | Transmission - Rearend | 5 | 09-02-2003 06:48 PM |
| 5 speed tranny with forward shifter? | Warm_Spit | Transmission - Rearend | 2 | 08-13-2003 08:09 AM |
| putting 68 floor shifter in 67 questions? | DeathByGreaser | Transmission - Rearend | 1 | 10-23-2002 05:06 AM |
