I used a dado blade on a table saw to cut the recesses on the edge of the planks where the metal strips go. I used Helmsman exterior poly-urethane varnish put out by Min-Wax to seal the wood ( three coats sanded lightly between coats) after I stained it. I used a golden oak stain also put out by Min-Wax.
If the truck sits outside, you may want to stay away from a finish like polyurethane or varnish, etc. As the wood ages, it will make tiny cranks in the finish and you may end up with dark grey stains where all those cracks are.
I've had great luck with our native ASH if it sits out and stays wet. it's pretty darn stable as far as not warping. |
This is the method I used for the interior wood on my Mercedes and I plan to use the same procedure for the wood bed in my 39 Plymouth truck.
Start by using an epoxy product by System Three called Mirror Coat, this is a one-to-one epoxy that is used for bar tops. It is crystal clear so it will not change the color of the wood. Coat all sides of the wood with epoxy including the end grain, this will seal the wood from moisture and prevent warping. Sealing wood with epoxy is what they use on wooden boats so you know it seals the wood. The epoxy is not UV resistant so after letting the epoxy cure sand it smooth with 400 grit/600grit paper and then coat it with a good automotive clear like SPI. The clear will provide the UV protection the epoxy requires. Since only the top of the wood is exposed to the sun only the top surface needs the clear coat. This is not an inexpensive solution but will provide a very durable finish. |
I wouldn't recommend table top epoxy on anything except table tops. It is too thick and won't penetrate the wood and will often peel of in thick sheets. I would use a coating of a good resin such as 'west system' using their hardener that is formulated to be clear or slightly tinted so it looks like varnish. (#207 I think).
I have a book on restoring pickups that includes a section by a guy who specializes in refinishing wood beds. While his process is rather lengthy, the gist is to use a few coats of a good quality marine spar varnish. The first coat should be thinned to the maximum recommended and subsequent coats should have progressively less thinner.
I did mine with unthinned low quality (from Ace) spar varnish and it turned out pretty good and quite durable. If I had it to do over, I'd have found some quality stuff that could be thinned to get better penetration and a smoother finish. Good luck... |
| fiberglass door panels, dash, center console, sub enclosure, amp rack | liftedbowtie | Interior | 74 | 09-14-2011 11:36 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| *Help* 72 Chevy P/U with Step Side Box *Help* | Mustangsaly | General Rodding Tech | 8 | 01-20-2006 08:07 PM |
| Wooden box floor for Chevy truck | OLDCHEVY | General Rodding Tech | 7 | 12-08-2005 05:56 PM |
| To Box or Not to Box - That is the question | H2Os50 | Suspension - Brakes - Steering | 7 | 06-16-2005 07:39 AM |
