Process when painting car with urethane bumpers - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-25-2012, 09:57 AM
Originally Posted by cyclopsblown34 View Post
TNSHADETREE, sorry for the threadjack.
Scoundrel!
But I think it's worked out well as a thread that addresses all aspects about urethane bumpers.
The Following User Says Thank You to TNshadetree For This Useful Post:
cyclopsblown34 (07-25-2012)
  #17 (permalink)
Old 07-25-2012, 06:48 PM
skip99's Avatar
just did a 79 trans am..hate all the palstic...but...had some really dry sun damaged areas, and a few gouges, so, I sanded all the original paint off, down to the plastic, with 180 da, went over it with 220, then used bulldog, lightly, 2 coats, then omni epoxy, thinned slightly, sat overnight, sprayed 1 coat urethane 2k, then da with 320, then wet sand to 400 grit, almost all the urethane was gone by that point, then black base, and 2 light coats clear, 1 coat would do on bumpers, but I buffed these.
if you are just sanding to original prmer, then you really dont need adhesion promoter, 400, is fine to go to epoxy, but thin it down a little,,, you could even skip the epoxy if the original primer is ok, but I would still use bulldog before base color...
Painting urethane bumpers? el pollo Body - Exterior 3 04-04-2011 06:28 AM
Painting process question richard stewart 3rd Body - Exterior 2 03-01-2010 02:40 PM
Urethane bumpers! Flintstone_flyer Body - Exterior 47 01-24-2010 04:30 PM
Prepping urethane bumpers and fiberglass parts? starquest Body - Exterior 19 12-21-2007 09:54 AM
Painting old bumpers dmcclellan Body - Exterior 1 12-31-2001 02:46 PM
