Procomp aluminum heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 04:15 PM
1967chevelle454's Avatar
Last journal entry: Before Retoration Begins!
I've recently purchased a set of procomp aluminum heads. I've got them from a quality machine shop kingsport,tn. They have rectangular ports and 2.25 1.88 valves. I was wondering what special parts or steps do I need to take to run aluminum heads vs. cast? thx
Old 02-22-2009, 04:20 PM
alert!
go on ebay motors, skip white, whiteperformance, he knows all about those heads...
Old 02-22-2009, 04:22 PM
re:
yeah, that's who I bought em from actually!
Old 02-22-2009, 05:43 PM
327 / 350 hp's Avatar
Aluminum heads
You do need to run special coolant that is alum- compatible.
Old 02-23-2009, 06:01 AM
dawg's Avatar
NAVY VETERAN
most coolants now a days are safe for aluminum
BUT!
make sure you use distilled water in your mix and a sacrifical anode in the radiator.
also procomps have been known problem makers.
I hope you got them for a good price.
Old 02-23-2009, 06:08 AM
Guy Hiltz's Avatar
When I got my Brodix RR heads,I took them apart and replaced the shim with a set of seat locators,heres a link;
http://www.compcams.com/technical/Ca...106-07/312.pdf.
I then checked pressures & height afterwards.
Guy
Old 02-23-2009, 06:41 AM
re:
Like I said I got this from a very good shop and I have quality parts to assemble them with. I'm also going to run them by my local machine shop to smooth the runners and check everything out. I got them for 965.00 for a set. pretty good i think
Old 02-23-2009, 09:03 PM
cool rockin daddy's Avatar
I would say that if you respect the ability of the shop you bought them from you should ask them their recommendations. Can help avoid any hassles on the small chance something goes wrong with them. They are warrantying them, not us.
Aluminum heads "imprinted" by gasket kunkle Engine 12 02-08-2009 11:28 AM
Aluminum Heads Vs. Vortecs(upgraded) boss350 Engine 5 01-15-2009 07:06 AM
Dart BBC Aluminum Heads jakejake1966 Engine 6 02-23-2006 07:27 PM
Opinions on Trick Flow Aluminum Wedge Heads 2506CYL Engine 10 02-24-2004 05:38 PM
installing motor with aluminum heads JH30906 Engine 3 06-05-2003 03:30 PM
