Hey guys. Finally got my pushrods in. I set up one cylinder, I have isky adjustable guide plates and I've run out of adjustment trying to center the rollers over the valve tips, seems as though both rockers have to be set towards each other so the plates have no more movement . Not sure if I should cut the plates and have them welded or if there are any other solutions? Pushrods clear the intake runners no problem. Wont be using these heads on any other builds every, have had nothing but problems. thanks for all the help
