Procomp fuel pressure regulator
I purchased a fuel pressure regulator from the local peformance shop procomp part # 2851. I was told it was a return style, from research on the net I have determined it is not. It has two outs. Im assuming one cant be simply used as a return, the gas will take the path of least resistance?? If this is the case, can it still be used? I got such an amazing deal on it. Thanks folks
Thanks so much DV for the quick responce. I have a holley 2300. How can I remove the jet?
Ok have the jet....stupid question earlier...4 screws..sorry...whats the best way to fasten it in the line?
The fuel line and return line are different sizes.... i believe 3/8 and 1/4. Would having the smaller diameter return line increase the pressure in the other? much like using the jet from the carb?
oh and one mroe question if I may...will the fuel take the path of least resistance? or will it simply put 2 equal amounts of fuel down each line, just at whatever pressure its regulated to?
15 lbs tbi pump
| Ram Jet 350 fuel pressure regulator | Ram Jet 55 | Engine | 0 | 07-01-2011 01:41 PM |
| Fuel Pressure Regulator | bprumos | Engine | 4 | 10-23-2010 03:51 PM |
| Fuel Pressure Regulator | muddi1 | Engine | 2 | 10-06-2010 11:24 AM |
| V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? | 5_speed | Engine | 18 | 10-25-2009 01:51 PM |
| bg fuel pressure regulator | 1931 steve | Engine | 1 | 09-15-2005 03:42 PM |
