-   -   product help & guidance (http://www.hotrodders.com/forum/product-help-guidance-227690.html)
Novicedoityourselfer 12-29-2012 10:28 AM
Recently painted with acrylic enamel (solid white color with hardener and reducer used) and have slight orange peel and overspray issues. What buffing/polishing compounds are recommended to be used with this type of paint to remove these types of issues to get that wet/glossy look back? Thanks
deadbodyman 12-31-2012 07:37 AM
first it needs to be wet sanded Id start with 1200 then 1500 You'll also need a rubber squeegie to get the water off so you can see how much you've sanded...
Novicedoityourselfer 12-31-2012 08:53 AM
Thanks. I've read that after the wet-sanding I should use a rubbing compound followed by polish, but there are so many products out there I'm a little confused. The consensus is to use 3M 5973, followed by 3M Finesse. Does that sound right? (I've spent the last nine months rebuilding/replacing the mechanics to my 64 Bird - engine, drive train, etc. My friend suggested and painted with the acrylic enamel. Gosh this car would look GREAT with a decent paint job!)
Old Fool 12-31-2012 09:44 AM
The way you say that it makes me think you have more than a "little" orange peel.
Novicedoityourselfer 12-31-2012 11:21 AM
Not rely. Just enough to be noticeable close up. When sanding it dulls the finish, so am looking for advice on the right product(s) to return the shine.
deadbodyman 01-01-2013 07:47 AM
Its kinda like asking which car is best chevy, ford or mopar ..everyone has their preferances...Theres been a lot of good cut and polish threads here I think it would serve you well to do a search of some of the older thread,theres a lot of great info there
