product help & guidance - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2012, 09:28 AM
Recently painted with acrylic enamel (solid white color with hardener and reducer used) and have slight orange peel and overspray issues. What buffing/polishing compounds are recommended to be used with this type of paint to remove these types of issues to get that wet/glossy look back? Thanks
Old 12-31-2012, 06:37 AM
deadbodyman's Avatar
Wiki Edits: 11
first it needs to be wet sanded Id start with 1200 then 1500 You'll also need a rubber squeegie to get the water off so you can see how much you've sanded...
Old 12-31-2012, 07:53 AM
Thanks. I've read that after the wet-sanding I should use a rubbing compound followed by polish, but there are so many products out there I'm a little confused. The consensus is to use 3M 5973, followed by 3M Finesse. Does that sound right? (I've spent the last nine months rebuilding/replacing the mechanics to my 64 Bird - engine, drive train, etc. My friend suggested and painted with the acrylic enamel. Gosh this car would look GREAT with a decent paint job!)
Old 12-31-2012, 08:44 AM
Old Fool's Avatar
The way you say that it makes me think you have more than a "little" orange peel.
Old 12-31-2012, 10:21 AM
Not rely. Just enough to be noticeable close up. When sanding it dulls the finish, so am looking for advice on the right product(s) to return the shine.
Old 01-01-2013, 06:47 AM
Wiki Edits: 11
Its kinda like asking which car is best chevy, ford or mopar ..everyone has their preferances...Theres been a lot of good cut and polish threads here I think it would serve you well to do a search of some of the older thread,theres a lot of great info there
Need Guidance Please !!!!!! "70" Cougar Hotrodders' Lounge 2 04-15-2008 07:00 AM
Need some guidance cameano Engine 5 08-30-2006 12:13 AM
Need some Guidance 36ford3window Body - Exterior 4 05-06-2006 09:31 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Looking for some guidance likestotinker Engine 2 07-25-2005 05:56 PM
