professional products fuel injection first start up issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2012, 06:47 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
i have a powerjection 3 efi system on my sbc and i cant get the damn thing started
checked spark spark is good so i shot some carb cleaner down the venturi and it fired for literally a second or 2 im very confused because im new to the aftermarket efi game and professional products themselves dont give much help either on their website or in their install manuals for trouble shooting problems...anyway i cant get her fired up and its so frustrating cuz im come such a long way and im right their its such a tease please any help is appreciated thank you
Old 04-08-2012, 08:38 AM
fuel spraying up out of throttle body???
just as it sounds i have fuel drop kinda jump up and around the top of the throttle body its a professional products fi system i had top spray a lot of carb cleaner down the venturi to get it to even idle for more than 2 seconds but it is now and now its doing that whats going on? thanks in advance
Old 04-08-2012, 10:30 AM
Banned User
i don't know; Me providing any input is like the blind leading the blind.
i'm assuming this is a chevy 350?
Did you put the plug wires in the right order?
Is the fuel pump putting out fuel and at the right pressure? Did you verify this and if so, how?
P.S. There are alot of other really good forums you could try that deal specifically with E.F.I. , but you probably already knew that.
Old 04-08-2012, 10:51 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You have two threads with the same issues, read the guidelines about double posting, it won't get you any faster responses, just have a little patience. I've merged them together here.
Semper Fi
Old 04-08-2012, 11:16 AM
sorry im just having a hard time with the car and its hard to tell whats related and whats not but the first one i couldnt get the car started now i have it running after a lot of staring fluid and it will stay running but the fuel spray issue i believe is the fuel system thinks its at WOT to its spraying a lot of fuel down the venturi but with the throttle blades closed its just bouncing off... anyway i apologize but im still looking for help possibly someone who has one of these systems and know a little more about it than i do
Old 04-08-2012, 01:23 PM
found that my tps sensor would not accept a calibration always at 100% throttle so i probed for power and found no volage anywhere also probed the sensor itself for resistance and found my meter registered that there was no connection and did not change as i turned the sensor...what the hell do i have a bad computer
Old 04-08-2012, 04:29 PM
T-bucket23's Avatar
Wiki Edits: 26
Check your grounds for the system.
Chet
Old 04-09-2012, 07:59 AM
this system grounds thru its carb studs that mount it to the manifold
Old 04-09-2012, 10:12 AM
T-bucket23's Avatar
Wiki Edits: 26
I would not depend on anything but a dedicated ground wire.
Chet
Old 04-09-2012, 06:31 PM
I'm not sure how it worked but I swapped out the tps an it works now I'm getting a full and accurate sweep of the throttle position I don't wt it considering that I sensed no reference voltage
Anyone used the professional products vortec intake?? redfish211 Engine 10 02-02-2012 01:51 PM
Professional-products Intakes Info? GoneNova/406 Hotrodders' Lounge 74 02-13-2006 05:01 PM
professional products 82c10 Engine 5 06-11-2005 07:28 PM
professional products ? babygene41042 Engine 47 05-11-2005 10:40 AM
Professional Products SBC-S-15 General Rodding Tech 1 10-14-2004 01:34 PM
