Proform Roller Rockers
Im thinking about buying a set for my 406, and im wondering if anybody has any experience with them pro/cons?
well the car is a 81 el camino my daily driver that sees the track 2 days a year, there 115can, i use proform pushrods and i spun my motor over 7k and they havent bent yet
Pro-Form....OK,
PRO-COMP...RUN THE OTHER WAY AS FAST AS YOU CAN. |
i have proform roller rockers for my vortec heads and they are very loud!! if you search other posts on this site you will see that it is common. i bought the proform valve covers to match for vortecs and the rockers actually rub the side of the valve covers. you think that they would make their parts more compatible.
that's my experience anyway. good luck. |
just one mans experience. i bought a set of proform pushrods trying to save a dollar. after 250 mile on a fresh rebuild it ate three of the end off the push rods. i now run comp. everyone i talked to after this happened to me said pro form wasn't all that great.
Proform makes fairly good non critical components, but I personally would not use any of their engine critical parts like rocker arms. My money for roller rockers would go to Comp cams.
just my 2 Vince |
Crane Energizer rockers can be had for about the same price and a lot more peace of mind. I replaced some Proform rockers with them once and it fixed the "noisy lifters".
Larry |
I have personally run the Proform "blue" rockers. They are loud and not built well (sloppy). This was years ago and maybe they have gotten better. I wouldn't give you a dime for them, they are right up there with CAT rockers (junk in my book). Crane Energizers as mentioned above by Larry are a good inexpensive rocker.
Royce |
well my exhaust is loud enough i dont hear any motor noise, the cam is a crower 278/284 duration, 462/470 lift. i used all crower valvetrain
Pro Form Rockers
I put Pro Form 1.6 full roller rockers on my 383 stroker. They are noisy as heck and I had to grind some off a couple to clear the valve covers ( cast aluminum ). So far no problems other than the noise but the clearance issue had me worried when I first started the engine and heard the banging inside the cover. They are cheaply made and I'm thinking of replacing them with Comp Cam units like the rest of my valve train.
Oljoedog Live long race hard |
I use the Crane roller rockers,I don't think the small difference in price is worth going to the cheaper brand.
Crane has a good track record,and good tech support,at least they've been good with me. |
| roller rockers or roller tip rockers | Jared | Engine | 18 | 08-01-2007 01:18 PM |
| Proform roller rockers! *** is wrong? | Sagacious | Engine | 21 | 11-23-2005 02:58 PM |
| Roller Rockers | black66 | Engine | 5 | 10-23-2003 07:32 PM |
| Proform roller rockers Anygood? | jl_zimmerman | Engine | 4 | 01-09-2003 08:43 PM |
| Proform Roller Rockers and Push Rods???? | cl5man | Engine | 2 | 11-04-2002 06:45 PM |
